Problems receiving text messages
  • Updated 1 year ago
I'm using an LG G5 bought in Nov. 2016 from Koodo online and I can send texts, but at least half of the time, I never receive the reply they send. I'm in Eastern Ontario. If I reboot, it will occasionally fix the problem temporarily. Is this is a phone problem or a network problem and what can I do to fix it? Other than very poor battery life, I like the phone.
Photo of Barry
Barry
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
Are you just not recieving replies from one person or multiple people? What kind of phone is your friend using? Is your friend having issues with other people or just with you?
Photo of Barry
Barry
I don't have that many conversations built up. One friend uses an iPhone, and I never get his messages. Another uses a Moto Plus. I often don't get his. And I do tests from my work BlackBerry and it's sporadic.
Photo of Allan
  • 56,526 Points 50k badge 2x thumb
If it's not working correctly on your blackberry as well you may need a new sim. Take it to a Koodo store and they can test everything out for you there.
