Problems loading tsn video on Android
  • (Edited)
For some reason my phone won't load tsn video iys takes long and need to click like 3 times it won't load on its own like my iPhone does. Is there a setting I have enabled ? Update : just browsing diff sites same thing I think I disabled something but can't figure what
Photo of ricardo Ferreira
ricardo Ferreira
  • 1,504 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
Are you connected to wifi?
ricardo Ferreira
Yes il on wifi. 150/MB down and 15 /MB up. It was working fine before now it struggles to plays . Is there any settings at all that I could of change that uses video playback because I was messing with some settings yesterday maybe I have sometjinhg turned down or off thanks.
ricardo Ferreira
For a example if I'm on twitter and there is a link there lets say tsn with a video I click on it takes me to tsn video but it doesn't auto play and there is just a ply button
Photo of Jonathan I
Jonathan I, Mobile Master
Which browser are you using?
ricardo Ferreira
I'm on chrome.
ricardo Ferreira
Please tell me what happens with your phoneCheck out @MapleLeafs's Tweet: https://twitter.com/MapleLeafs/status...
Photo of Veronica
Veronica
  • 3,528 Points 3k badge 2x thumb
Hi Ricardo,
Have you tried rebooting your device to see if it makes a difference? Also, depending on the size of the video you are watching, you may experience a black screen for a few seconds while the video is buffering.
Hope this helps!
