Problems changing my phone number
  • 2
  • Updated 2 years ago
I'm trying to switch my number online through Koodo self serve, but it keeps telling me it was rejected because my account number is wrong. I've checked the number ten times now and it is not wrong. Please help!
Photo of Aa Battery
Aa Battery
Posted 2 years ago
  • 2
Photo of Sophia
Sophia, Mobile Master
Are you trying to port in a number or just change it? At which point do you get the error?
Have you registered for a self serve account?
Photo of Aa Battery
Aa Battery
I have registered for a self serve account. I get the error after I hit the submit button to finish it.
After you try to finish registering for self serve?
Photo of Mayumi
Mayumi, Mobile Master
  • 115,066 Points 100k badge 2x thumb
Are you trying to change your number within same province one or different province number?
Photo of Aa Battery
Aa Battery
In the same province.
Photo of Mayumi
Try clearing browsing history and try again.
If you still have issues, I would call tech support. *611 and option 6
Tell them you tried change the number through self serve, but you got error message saying " your account number is wrong".
They will help you :)
(and there is no charge for this call since you tried and can't do it)
Photo of Aa Battery
Aa Battery
Thanks for your help. I got it changed.
Photo of Mayumi
What did you do?
Clearing browsing history or called in or something else?
Photo of Aa Battery
Aa Battery
I just called in and they did it for me.
