Problem communicating with google servers???
  • 7
  • Updated 2 years ago
I am not able to sign in to my google calendar on my Android phone. I've already written a question on this and received an answer...but every time I try to add my google email address, I get the message: 'There was a problem communicating with Google servers. Try again later.' I've been trying for weeks now but it keeps saying the same message. Please help. Thank you!
Photo of Genevieve MacIntyre
Genevieve MacIntyre
  • 160 Points 100 badge 2x thumb
  • 7
Photo of John Burke
John Burke, Mobile Master
What's your device?
What Calendar App are you using?
Try in Settings--> Accounts--> Google to toggle off "Calendar" & toggle it back on.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
You do have data or wifi turned on, right?
Genevieve MacIntyre
Sorry...I don't know what toggle means.... I am using a Nexus 4 android. Yes I have data and wifi on...everything else seems to be working except communicating with the Google servers.
Photo of Saya Soe Than
Saya Soe Than
  • 116 Points 100 badge 2x thumb
My mobile is google service comunicting problem, please help..
Saya Soe Than
I can't login enter play store.
Saya Soe Than
Please help or link
  • 139,982 Points 100k badge 2x thumb
Photo of rikkster
rikkster, Mobile Master
If you're using the Google Calendar app and not the Nexus 4's built-in calendar app, navigate to the Play Store (on your device or click on link below) and download the Google Calendar app. There may be an update, if not, uninstall the app and reinstall.
https://play.google.com/store/apps/de...
Genevieve MacIntyre
THANK YOU RIKKSTER! Success!
Photo of rikkster
  • 66,988 Points 50k badge 2x thumb
You're welcome Genevieve! Glad we were able to finally get that working.
Photo of Christopher Latham
Christopher Latham
  • 62 Points
There is currently an issue, since sometime last year, with android devices and Google apps and services. When I use Google chrome app, Google search app, or any Google apps they try to automatically log in to Google servers, right at startup, and then about every minute or couple of minutes again, because Google is trying to make everything synchronized with your account on every device that you access the internet, and if you agree with the terms of service they also are taking record of every search you do, every site you visit, every app you use, and everything you do online with Google to customize everything Google related, for you personally. It is very annoying and I hope that Google fixes the problem. I believe it is only an issue on newer android devices, because I had an LG L45C for a couple years, with no problem, and then I just got an LG G2 LS980, which has Android 4.2.2, and that message has interrupted me writing this about 8 times so far. I see while searching for an answer online, which is how I got here, posts going back to at least June or July of last year, and still today I'm getting the message. I'm sure it'll be worth it when it's all complete, and fixed, cause Google has a quantum computer now which I'm sure is processing a ton of this data, but it sure is annoying now.
