Problem with my Samsung Galaxy S4!!
I have the Samsung Galaxy S4. I purchased this phone a couple of months ago...maybe in January. So, almost a year. When I recently got this phone, it was working perfectly fine. After a few months of using it, it began to restart automatically at random times. This is starting to happen more often than it did before. Has this happened to anyone? I am not sure what to do. Should I the Koodo located near me? If so, will they be giving me a replacement phone? Thanks!
Photo of danica mae
danica mae
  • 80 Points 75 badge 2x thumb
  • concerned.
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Joannie,
What you're describing is a software issue with the phone, there have been plenty of reports of people having issues with their Samsung devices restarting randomly on their own. Now what needs to happen in order to fix these issues generally is to do a factory reset of the device.
The steps to do that on the Samsung Galaxy S4 are as follows:
1.From your home screen press the apps icon in the lower right corner.
2. Find and press the settings icon.
3. In the upper end of the screen press the accounts tab.
4. in the bottom of the next screen press the Backup and reset button.
5.Press the factory data reset and;
6. Read the info on your cell phone screen and hit Reset device.
**Before you do any of this be sure to back up your data from your phone so that you can restore it later**. If this doesn't fix said issue you can take the phone in and see if you can get it looked at as it is still under warranty.
Hope that helps! :)
Photo of danica mae
danica mae
I have actually tried this before - multiple times. My phone still keeps on restarting. Thank you for trying to help tho!
Daniel Gunn
You're welcome! If that hasn't fixed the issue you will have to see if the nearest Koodo kiosk will send it in for warranty servicing and see if they can fix the issue that way, that's the only other thing I can suggest.
Hope something gets sorted out for you.
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
You know this should not happen if a phone made well you should not replace it at all koodo please look in to this is not acceptable thank you all ways wen I use my tab same problem way is this happening can some one make sense out of this I have post a comment no one got back to me lol os I'm asking Gen my contact disparying only shows up to on my goolge account
what is going on here
Photo of Sophia
Sophia, Mobile Master
Hi Matthew,
You said nobody came back to your question. I have to be honest here, I can't answer your questions because I usually have no idea what you are talking about. I guess that English is not your first language?
Do you have a friend perhaps, or a relative, who you can pose your problem to verbally and then ask them to write down your issue in clear, concise language and in proper English (or French)? That way you KNOW you will get an answer. We are all willing to talk to you but it is a bit hard to understand you....
