Problem of accessing voicemail abroad
  • Updated 2 weeks ago
Is it possible to check voicemail when roaming outside of canada? .
I am in Germany, and I have internal roaming in my plan. However, I cannot call or send text to any number (so cannot access my voicemail from my own cell phone). Is it possible to retrieve my voicemail by skype call?
I tried to call my phone number by skype, as suggested in some threads, but it only connected to my cell phone as an incall, did not access to my voice mail. Could any one please help me, thanks a lot
Photo of Ruo-Xu Gu
Ruo-Xu Gu
  • 150 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Dennis
Dennis, Mobile Master
When you call your own number and you get your voicemail, you need to press the star "*" key to get your password prompt
Photo of Ruo-Xu Gu
Ruo-Xu Gu
I called 1+my phone number by skype, and it shows in my cell phone as an incoming call, was not able to access voicemail.
I also did this using my cell phone, however, as I mentioned, I cannot call any number (even I have active international roaming), this also fails
Could you be more elaborate on your suggestions?
Photo of srlawren
srlawren
  • 2,018 Points 2k badge 2x thumb
How are you dialing your phone number?  When you dial from your cell in Germany, you would need to dial 011 + your 10-digit phone number.  https://www.howtocallabroad.com/results.php?callfrom=germany&callto=canada
From Skype, I'm not sure what you would do, possibly the same or maybe just your 10-digit number--I'm not quite sure.
Photo of Mats
Mats
  • 10,714 Points 10k badge 2x thumb
Your link says 00
Photo of Mats
Mats
Your link says 00
Photo of Mats
Mats
So try 001 then your 10 digit number. As srlawren link says do not put in the +.
Photo of Mats
Mats
