Pro-rated Credit
  • Updated 6 months ago
I canceled my $65/mnth Koodo plan on Dec 19 and my cycle starts on the 1st or 2nd of the month. WIll I be credited the 10 days I didn't use? And should this be reflected in my January bill statement?
Photo of sl
sl
  • 160 Points 100 badge 2x thumb
Posted 6 months ago
Photo of Allan
Allan, Mobile Master
  • 62,856 Points 50k badge 2x thumb
Yes, you'll see the prorated amount for the days you didn't use.
Photo of sl
sl
So my January statement has a balance of $0, with no credit.
Photo of Allan
  • 62,232 Points 50k badge 2x thumb
A balance of $0 would mean there had to of been some sort of credit otherwise you would've been charged right?
You can check your pdf ebill to see the full breakdown.
You must have cancelled exactly half way through which means you got charged for half the month and got reimbursed for the other half equaling $0.
Photo of sl
sl
I checked the full breakdown in the ebill PDF and there are zero charges (i.e. every line item shows $0.00. And I had paid off my December bill in full and had no other outstanding charges/balances.
I canceled my plan with 10 days left until my next cycle. Is this enough to receive a credit back? I read in the community forum that Koodo does pro-rate bills so I assumed I would be receiving a credit but I didn't get one in my January bill.
Photo of Dennis
Dennis, Mobile Master
  • 196,816 Points 100k badge 2x thumb
If you used more than your pro-rated amount of minutes or data, then you would incur overage.  If this overage amount exceeds your regular monthly bill, then Koodo will charge you until the end of the month since it will save you money.
Photo of sl
sl
I just checked and my data usage on my bill says 1,669.227 (MB) and my plan gave me 4 GB of data with unlimited calls & text messages. So it doesn't seem I used more than the pro-rated amount. Or am I wrong?
Photo of sl
sl
Ok, thanks.
Photo of Allan
Can you send a screenshot of what you're seeing on your final bill? Just leave out any personal information.
Photo of Allan
Photo of sl
sl
Photo of Allan
Could you screenshot the top of page 3, right above the part you showed?
All this is saying is that you werent charged any overages. You want to look at your plan costs which is right above this on your pdf ebill.
It'll look something like this:
Monthly and other charges (Dates)
*Your plan details*
Total monthly and other charges $xx.xx
Photo of Goran
Goran, Mobile Master
  • 97,738 Points 50k badge 2x thumb
If you do call Koodo they will not charge you for calling.
Photo of sl
sl
Thanks for answering that question!
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,726 Points 100k badge 2x thumb
When you cancelled your account did you request that it be cancelled effective immediately? If not, the default would be to cancel at the end of the current billing cycle.
Photo of sl
sl
I did. I received an email from Koodo right away confirming the immediate cancellation.
Photo of Robert
Robert, Mobile Master
  • 107,160 Points 100k badge 2x thumb
Yeah the account does get cancelled immediately but for many reason Koodo charges the whole month unless you specifically ask for.
Photo of Ry
Ry
  • 5,552 Points 5k badge 2x thumb
For me, I ported my number 7 days into a billing cycle in December. I got the email the same day that my service as cancelled and my final bill would be January 10th. At the end of December, they took out my month payment for December 10th to January 10th.
However, my final bill, there is no pro-rated credit. It said I owed 0 dollars.
I would have expected a credit of from December 18th to January 10th.
Photo of Dennis
  • 196,374 Points 100k badge 2x thumb
You will need to contact Koodo to let them know you wanted your bill pro-rated and not canceled at the end of the month
Photo of Ry
Ry
Would have thought porting out would have triggered that automatically. Thanks for the suggestion
Photo of Dennis
I thought so too, but apparently it needs to be requested or else it gets canceled at the end of the monthly billing cycle to avoid any surprised overages that certains users might incur
Photo of J
J
  • 230 Points 100 badge 2x thumb
Yes, sr as long as you called in to cancel the system will reprocess your bill and will credit you back the days you did not used the services. as long as you dont have any extra charge.
