Printing out my bill with self serve.
Why cant I open my e-bill to print it out. Never had a problem before. Now when I try to open it I get a message box pop up saying the bitmark file or format is not supported. Thank You
Photo of Rhonda Grassinger
Rhonda Grassinger
Photo of Chris Petersens
Chris Petersens
It is likely software on your computer that may need an update or a plug-in. koodo 's bills are in an adobe file format, so at minimum you need an adobe reader. You can find it online cost nothing to download.
