prepaid phone not working/connected?
  • 2
i just set up my prepaid koodo phone and it is not working. What can i do?
Photo of Vickie Nelson
Vickie Nelson
  • 2
Photo of Dennis
Dennis, Mobile Master
  • 187,472 Points 100k badge 2x thumb
Pull out the sim and battery for a few mins and try again
Vickie Nelson
I did that and nothing changed
Vickie Nelson
it says the sim card is unregistered
Photo of Dennis
Then you haven't activated your phone. Check your self serve. Make sure you SIM card # was entered correctly.
Vickie Nelson
i've been on hold with koodo for almost over an hour now. Still my phone shows it is unregistered. I try to make calls and it says "mobile network is unavailable"
Photo of Dennis
Make sure your 3G is on.
Settings, Mobile Data, and then Mobile Networks. Make sure it's not on 2G GSM ONLY. Select GSM/WCDMA or GSM/HSPA
