Pre-purchase questions
  • Updated 2 years ago
hi
I'm a very light user of my iPhone, composing very few text messages and even fewer calls. Koodo seems to fit my needs in terms of cost and ease of account management. Before I sign up I was hoping to get some questions clarified and any suggestions folks might have.
I'm looking at getting the most basic of monthly plan ($15/month) and then use a booster add-on for anytime minutes.
Does this seem like a reasonable approach? Given that add-on boosters unused credits are carried on as the plan is renewed this seems like a good option.
Am also thinking of having pre-authorized plan renewal, if I understood this option correctly it gives you back a 10% credit.
Any suggestions and comments are welcome. Glad to see this seems like a very active and helpful community. - cheers
Photo of ipadfsj
ipadfsj
  • 724 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi ipadfsj,
If all you are doing is what you say, then this seems like a very good option! The minute boosters are also Canada-wide so you can even call from anywhere in Canada to anywhere in Canada. As for the pre-authorized plan renewal, you are correct about the 10%.
Just a reminder, the booster minutes you add carry over as long as you keep your base-plan active (paying the 15$ every month) so I would recommend you add the 500 minute booster, it's the best value for your dollar (0.05$ per minute). The 100 minute booster ends up costing you 0.10$ per minute and the 25 minute booster costs you 0.20$ per minute. If it takes you an entire year (or more) to use the 500 minutes, just make sure you keep renewing your base plan!
Photo of BobTheElectrician
BobTheElectrician
  • 61,676 Points 50k badge 2x thumb
It's a great way to start. You won't be locked into buying services you don't need, and if you go a little overboard, your service stops and you can re-assess your needs instantly. No big end-of-month surprises because you accidentally left mobile data on.
My plan is exactly what you propose. Costs me less than $25 a month on a yearly basis all-in for mixed light to medium consumption.  Pre-paid bridges the peaks and valleys nicely.
Only drawbacks with prepaid:  no service at all outside of Canada, and some rarely-used features such as extended roaming or call forwarding do not work.
Photo of ipadfsj
ipadfsj
Thanks for the quick and helpful replies.
Mathieu: that's a great suggestion to go with the 500 min booster, will do that
Bob: I don't use my phone outside Canada, but thanks for pointing that out
On another note, looks like I can activate the phone myself online after I get a sim card (I think Walmart sells them for $5). When it comes to getting a phone number assigned, will I get a few choices to pick from?
Photo of ipadfsj
ipadfsj
When I purchased the SIM card one thing the Koodo rep suggested is that I turn off iMessage in the iPhone Settings. If I understood him right his reasoning was that iMessage will use data, by turning it off it forces the phone to send messages as SMS, which does not affect unlimited text messaging. Does this make sense? thx
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,976 Points 10k badge 2x thumb
100% right ipadfsj !
Photo of ipadfsj
ipadfsj
Great!! Also, if I don't plan to surf the web on cellular, can I shut off Cellular Datain the Settings? I'm not sure if that would also take away my ability to make phone calls. What would happen if I shut off Cellular Data? Basically I just use the phone for calls and texting (imagine that :))
Photo of Mathieu
Since your prepaid, there is no real use of turning off Cellular Data. By turning it off, you will stop MMS (picture messages) from being able to be sent or received from the phone. With prepaid, if you don't have a data booster, then it will not allow you to use data thus ensuring you get no additional charges.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,962 Points 100k badge 2x thumb
Just want to add that, depending on the version of iPhone you have, only turn off cellular data, not 3G.
Photo of ipadfsj
ipadfsj
It's a 4S so 3G is a separate option. That's good to know that if I don't have a data booster it will not allow me to use data, because I think with major carriers that's not the case. So if I don't have data booster and DO NOT turn off Cellular Data I won't be able to send or receive MMS correct?
  • 139,892 Points 100k badge 2x thumb
On prepaid mms should work with or without a data booster, as long as data is enabled.
Photo of Mathieu
MMS will work, but you must have your data turned on. If you turn data on the phone turned off, then MMS won't work
Photo of ipadfsj
ipadfsj
just activated my phone and thanks to all the help above it went without a glitch and works great !!
However I'm having trouble understanding the transaction amounts and balance it shows. I've pasted the transaction amounts below hopefully it won't be too messy, but I'm trying to decipher what it's telling me. Is the activation bonus what came with the prepaid sim card? I also got a text from Koodo telling me that I have a free 100 minute talk booster but I don't see that. Any help deciphering this statement is appreciated thanks
Jan 31, 2016ATU Discount 10% - PP15/ATU Remise de 10% - PP15$1.50 $1.50 Jan 31, 2016Talk Booster 500/ à-côté Parler 500 $25.00$0.00 Jan 31, 2016$15 Base Plan Purch/Achat d'un forfait de base 15$ $15.00$25.00 Jan 31, 2016Activation Bonus / Prime d'activation$20.00 $40.00 Jan 31, 2016Credit/Visa Debit TopUp-Réapprov crédit/Visa Débit$20.00 $20.00 <<<[1]>>>
