post paid plan
  • Updated 1 month ago
Hello I'm currently on Koodo postpaid. I am on a month-to-month as I brought my own Samsung Note 5 to the company however my question is I continuously try to find a plan with the highest amount of data gigs as possible when I check current plans I see two different plans that have all the exact same information in them and features and both have 10 gigs of data but one is $80 and one is $90 what is the difference as I see no difference in what is included in the plan. And would Koodo by any chance send me an email or something with a better plan than what's available just on that website cuz I did bring my own device. I am originally from BC currently working in Manitoba soon to transfer to the Northwest Territories if this makes any difference
Photo of rick mawn
rick mawn
  • 162 Points 100 badge 2x thumb
Posted 1 month ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 206,346 Points 100k badge 2x thumb
They're the same plan just different tab sizes, you pay more for your plan the larger tab you aquire to get a larger discount or payment offset for a phone you could aquire using a tab.
Since you have you own phone look at the no tab plans which are cheaper since you don't require a tab, unless you want to lock in the plan to be able to take a tab later on and that plan may not be available. Depending when you think you'll want a new phone if in a tab.
Photo of rick mawn
rick mawn
Thanks but I don't see a plan specifically that says no tab plan do you have a link to the page that consist these of these plans?
Photo of BobTheElectrician
BobTheElectrician
  • 69,788 Points 50k badge 2x thumb
Go to:
https://www.koodomobile.com/rate-plans
Click on the appropriate province and language and No tab under the Select a tab type box. Pricing will depend on the phone number. BC and NWT plan prices for unlimited/unlimited/10 GB data seem identical at $90. Your current plan may have been a bit cheaper when bought than the current one. You can stick with it if you are willing to live with your current phone number.
Photo of Dennis
Dennis, Mobile Master
  • 201,104 Points 100k badge 2x thumb
Hmm.... I can't find your $80 / 10gb plan anywhere for MB, BC, or NWT.
Do you have BC or MB phone number?
If you can't find your plan anywhere on koodo's website, then I think you may have a special deal on your account.
Photo of rick mawn
rick mawn
8in the pictures above
