Porting phone number before changing it
  • Updated 2 years ago
I would need an informed opinion on the following scenario. My current Koodo phone number has an area code from Montreal. I’m relocating to Toronto. I’d like to change my phone number to a number from Toronto area code (which I believe I can easily do online with Koodo self-serve service?) but I would like all calls made to the old, Montreal area code number to be forwarded to the new Toronto number. I beleive that I can do that by “porting” my current number to a service such a CallCentric or voip.ms, am I correct? What would be the step to follow? 1) Port the current number; 2) wait for the porting to take effect (couple of days); 3) then ask Koodo for a number in the Toronto area? Any advice will be greatly appreciated! I’m new to all this. Got my first cell phone only a couple of weeks ago.
Photo of Philippe
Philippe
  • 220 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
Hi Philippe, when you port your number out, you automatically cancel your line with Koodo. What you want is not possible,,, you can only change your number or port a new number in, but either way you'd lose your old number.
Photo of Sophia
The only other option is to add a new line to your account with an Ontario number, and close the old account by porting out, but you'd have to pay off your entire tab then.
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
You can do it backwards: get a new Toronto number from CallCentric or other VoIP and have those Toronto calls forwarded to your unchanged Montreal number without having to port your number, pay off your tab or abandon your current plan for something less generous in Ontario.
None of your current contacts or newer Toronto ones will be discouraged to call you by long di$tance charge$. Buy a SIP box hooked up to your home internet and you have a landline at home with the Toronto number as well.
Bon voyage. Feel free to ask any further questions.
Photo of Philippe
Philippe
Thank you all for the comments. Thanks Bob: the advice is interesting and CHad’s instructions a clear and easy to follow. With all this, I’ll manage to find a suitable solution!
