Portable Wifi Hotspot Not Working
I just got an unlocked G3 and set up the APN settings for mobile data to work. It works fine I get the internet no problem. When I try and set up a Portable Wifi Hotspot it never works. It says there is a temporary network problem that prevents the enablement of the mobile hot spot. please try again later. I saw something about putting the word "DUN" into the APN settings but I don't understand how.
Photo of Brendan Landry
Brendan Landry
  • 190 Points 100 badge 2x thumb
Posted 3 years ago
Where the apn said apn type you need to add that DUN
Brendan Landry
K so I created a APN Named "Koodo Mobile Data" put sp.koodo.com under APN and at the bottom it says APN Type and I put DUN in there and now data and mobile hotspot both don't work. haha I must still be doing something wrong.
Also needs to have :
default, dun
Brendan Landry
That makes sense. I did that and now the data works again but hotspot is still giving the same message when I turn it on. hmmm thats weird
Photo of Mathieu
Mathieu, Mobile Master
did you by chance put a custom rom on your phone or is it still running all the default android system it came with?
Brendan Landry
I bought it used and didnt change anything myself but I did notice there is a ton of AT&T stuff on it from the previous owner if that matters
Photo of wugooey
wugooey
  • 290 Points 250 badge 2x thumb
I have the same problem with my G3, I did a search on the internet, it seems it's a common problem with the G3.
Photo of BobTheElectrician
BobTheElectrician
  • 65,914 Points 50k badge 2x thumb
There is no shortage of everyday wi-fi problems reported with the G3, let alone trying to use it as a wifi hotspot.
Type" lg g3 wifi" into the search box at the top of this forum's page, then google it if you want a full day's entertainment.
Can't believe that after all this time, wifi or basic mobile connections continue to be a problem with certain LG, Samsung or other makes of devices while other cheaper models from the same manufacturers are absolutely bulletproof.
Photo of rikkster
rikkster, Mobile Master
Remove 'default' and 'dun' for the time being. Try using an asterisk (*) under APN type, minus the brackets. Don't forget to save the modification to the APN and do not reboot your phone.
Brendan Landry
So it turns out it was At&t blocking the hotspot. After some video searches I found out how to remove at&t's settings. Thanks for the help too.
Please post what you did so others may benefit
