Poor signal on any mall, building, houses or even outside.
does any body knows why koodo signal is terrible inside a building or a house and even outside?
I working indoor and those who have rogers, fido, mts has full bars and i don't get a single bar???
I have to get to a window, or just go outside.
have 2 samsung s2x.
i tried:
pulled battery out and put back on.
turn airplane mode on the turn it back off.
change network mode then put it back to auto.
that's on both phones.
thanks
Photo of Rex T
Rex T
  • 430 Points 250 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,766 Points 100k badge 2x thumb
Where in MB are you? Koodo's hspa network only covers a small part of southern MB, while Rogers and MTS share towers and have roughly equal coverage everywhere.
Photo of Rex T
Rex T
winnipeg
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
How come this topic is labelled as "answered?"
Photo of Rex T
Rex T
that is weird.
because is not.
Zaphod Beeblebrox
Since you did most of what I would want a customer to do, which is great you did all that, what would most likely need to happen is to call to Koodo Tech Support and have them check the SIM card information. There could also be an issue with the phone or sim physically. Testing the sim card in another phone is a way to see if the same situation happens. If it does, replace the sim. If the issue lies with the phone, see about repair options.
Photo of Rex T
Rex T
thank for the info.
I'll do that.
Zaphod Beeblebrox
Hope it all works out for you :)
If you like, post an update when you get a chance. I'd like to know the end result :)
