Poor signal
  • 2
  • Updated 1 year ago
Very bad network signal everywhere. Put my rogers sim in my phone to compare signal and rogers is 100% better signal. I also don't get 3g on my koodo sim. Not sure why.. And I have a Samsung s3. And my APN is correct. And I have data enabled.
Photo of tyler pozdnikoff
tyler pozdnikoff
  • 80 Points 75 badge 2x thumb
  • sad
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,572 Points 100k badge 2x thumb
Make sure your phone isn't set to GSM but it's set for CDMA in mobile settings.
Also go to your APN settings & make sure you delete all the APNs except for Koodo
Photo of Yokhanna Besawa
Yokhanna Besawa
  • 74 Points
Thank you so much
Yokhanna Besawa
  • 74 Points
I tried the CDMA and it went from 1 bar to 5 barso. But my question is does that effect anything?
Photo of titaniumtux
  • 12,892 Points 10k badge 2x thumb
If you're only using Koodo, won't affect anything (assuming that your connection is working, browsing, calls and texting works, etc.). I know for older phones (example S3), it's often required to configure the carrier's APN manually (newer phones usually do it automatically unless it's a roaming SIM).
