poor signal
  • Updated 2 years ago
Does anyone else in the Rosemont area of Montreal have terrible reception?
I get zero reception in my actual apartment, and minimal reception when I leave but stay in my neighbourhood. Anyone else have this problem?? Chatted with Koodo customer service briefly and they told me to reboot phone, remove and replace sim and battery, that did nothing.
What the hell would I do I had an emergency and needed to call 911?? I'd be screwed.
Photo of moni
moni
  • frustrated
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 91,406 Points 50k badge 2x thumb
Are you connected to lte or the 3G network? I remember Telus/Koodo use to have dead zones in Montreal but I figure that they'd be long since fixed by now. I certainly don't recall there being issues in Rosemont. What happens when you're outside of Rosemont? Is it the same or does the reception improve at all? If it doesn't get better or only minimally so and you're connected to 3G/WCDMA then it could be that the Sim card needs replacing.
Photo of BobTheElectrician
BobTheElectrician
  • 62,208 Points 50k badge 2x thumb
Android:
Wireless and networks => Mobile networks => Network mode
Here you can toggle LTE / WCDMA / GSM. Sometimes a phone will be happier without LTE if that signal is weak or unavailable in the current area.
Photo of moni
moni
Ah, it's already set to GSM/WCDMA/LTE AUTO...so I guess it automatically selects the strongest signal? which...isn't working...
BobTheElectrician
The phone automatically selects the strongest tower, which could well be a 3G signal.
If LTE is weak but nevertheless available in your apt., the phone will neverthess waste a great deal of energy trying to grab onto that signal on Band 4 (1700/2100) if you've enabled it. Those are the bars you will most likely see in the notification area if LTE and data are enabled.
The rest of the phone comms work on 850/1900 frequencies (3G).
Temporarily drop the LTE from your choice. See if it makes a difference. And you can still get data on 3G without the LTE, just not as quick.
Photo of moni
moni
Ok will try that later at home....thanks so much!
Photo of Goran
Also don't worry about 3G being slower. It's "slower" but I personally get 20+ mbps pretty reliably in Toronto/Montreal on 3G. It's fast enough for loading anything quickly. Even 1080p streaming doesn't go over 6mbps.
