pls clarify; '5pm evenings & weekends; unlimited Cdn LD': means LD calls outside this window comes out of 'anytime min?
  • Updated 2 years ago
Photo of Bru Sabourin
Bru Sabourin
  • 190 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Bru,
If your plan comes with a set amount of minutes, then you can call anywhere in Canada from anywhere in Canada (as long as it's not a local plan) and it will count towards those minutes. If you call during the unlimited evenings and weekends window, then it does not country towards those minutes.
Bru Sabourin
Hi Mathieu, thank you so much for clear explanation!  ...just want to understand what you mean by 'as long as it's not a local plan'?
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
Some plans have "local" calling, which means that if you make a call to outside of your local area OR are outside of your local calling area when you place the call, LD charges will apply. I believe it's 50c/min.
Bru Sabourin
I think(?) I'm covered for Local calls as well, as my plan states that I also have 'Unltd local Family calling' ...do you agree?
Photo of Jonathan I
That's only between all the lines on your account. If your plan doesn't say Canada-wide calling anywhere, you are subject to local calling conditions.
