please help
  • Doesn't Need an Answer
could you please tell me why i have no service with my phone today have no bars at all
Photo of Theresa Smith
Theresa Smith
  • 112 Points 100 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
All day, Theresa? Did you try switching off the phone for a few minutes, or manually search for the network? Whereabouts are you?
Photo of Jaye Roberts
Jaye Roberts
well i was going to tell you the same things...it does happen to me but after i have turned it off and on it comes back...
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
Check to see if Airplane/flight mode is checked/activated on the phone. Also look in the settings to be sure that 2g is turned off (the alternate name is GSM only. In most android phones, the "network mode" should be at GSM/WCDMA AUTO or GSM/HSPA AUTO. Blackberries network mode should be 2G/3G. Iphones would have a setting that says "enable 3g." Makre sure that is on
