Please help.
I really need some help, I want to get the iphone 5c, with the 500$ tab you only pay 75$, i'm currently on the tab right now with koodo, i still owe close to 100$ on my current phone, however, the phone will be given to my parents and i will be adding another line to my account, can i still own both phones? without having to pay off my prevous tab?
Photo of Sarah Itworks
Sarah Itworks
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,250 Points 100k badge 2x thumb
You will have to get the second line if eligible (not on a spending limit) and then use the tab on that second line. The second line will have to have a tab large plan to be eligible for the large tab. There will also be a $10 per month tab charge added on top of the tab large plan.
If you do all that then there's no need to pay off your tab on the first line.
Sarah Itworks
okay, i'm not on a spending limit, i just wasnt to sure if i had to pay off my old one to get my new one. thanks soo much for your help!
Photo of Jonathan I
Jonathan I, Mobile Master
I highly recommend going on Medium Tab instead. You'll end up saving money and/or getting better value in your plan over 24 months in almost every circumstance versus getting a cheaper price in store.
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
We did the math some months ago Sarah, listen to Jonathan's advice. You'll save a pretty good chunk of money over the next 24 months even if you have to shell out more up front!
Photo of Steve Glover
Steve Glover
  • 222 Points 100 badge 2x thumb
I'm looking at the identical situation except for my wife instead of parents. Would you still be able to keep the same phone number? Would the current plan still be in effect for the phone or would I lose it?
Photo of Myke
Myke
If you go on Tab M, you will need a rate plan of $30. If you go on Tab L, you need a Tab L plan.
Everything else would remain the same.
