Please help....
  • Doesn't Need an Answer
Hi,
I had bought a sim to fit smsung galaxy s3, but now I am thinking about getting a samsung discover due to budget issues.. Will the same Koodo sim fit it in the discover too, or will i have to go back to the store to change.
Photo of Jyotsna Krishna
Jyotsna Krishna
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
According to a list of specs I found it will take a Micro SIM Card which is the same as the Galaxy S3.
Photo of John Burke
John Burke, Mobile Master
If ever you switch to a device with a different sized SIM slot you can switch it back on Self Serve to your previous SIM.
Personally I get mine cut & keep the remainder to be used as a "shell" to put inside so I can swap my same SIM between 3 different sizes.
Photo of Myke
Myke
If switch between 2 different sim cards, make sure to swap them at least once during a 90 day period so then 1 of the sim cards do not go inactive.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
I can confirm that no it will not fit, you need a mini sim ("regular" sized one) which is roughly twice as big as the micro.
  • 199,404 Points 100k badge 2x thumb
I guess the specs I found were wrong, thanks for the correction Jordan. Do you have the discover, how is it?
Photo of Jorden
I don't have it personally, but I've seen a few of them. Not a horrible phone but very very basic. I'd give it the edge over the Ace but not the Ace 2.
