Please help! Travelling soon!!
I'm going to be travelling to LA for a few days then down to Central America for 3 weeks...if I have my roaming turned off and I have WIFI where I'm staying will I get charged for texts and for using FaceTime or Skype? Thanks!!
Photo of Candice Cooper
Candice Cooper
  • 166 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 106,744 Points 100k badge 2x thumb
Incoming texts in the US are free! In Central America, I would suggest to put your plan in airplane mode. Outgoing text will not be free unless you use iMessage.
With roaming OFF, you will not get charged for any data use.
Bottom line, if you want to make sure you don't get any charges you have 3 options
-Airplane mode
-Buy a roaming package for the US
-Unlock your phone and go prepaid on those countries
Here's the info for roaming packages in the US : http://help.koodomobile.com/coverage-...
Photo of Ivan
Ivan, Mobile Master
You can manually turn on WiFi after placing your phone in airplane mode.
