Please help!
  • Updated 2 weeks ago
I have a 1g data booster. I have only used 106.05mb and I was sent a txt saying I used 1/2 data. Then no data? Yet I still have 950mb and can't use it. I waited 45mins to talk to a rep. Then was disconnected. Please help!
Photo of Peter Muir
Peter Muir
  • 84 Points 75 badge 2x thumb
Posted 2 weeks ago
Photo of Dinh
Dinh, Mobile Master
  • 45,894 Points 20k badge 2x thumb
hi Peter,
Have you checked your selfserve and see if the baseplan was active? you need to maintain the baseplan to use the booster.
If everything was ok in your selfserve, I would suggest you restart the phone, or/and reset the network settings and see if it could help.
Photo of David
David, Mobile Master
  • 96,172 Points 50k badge 2x thumb
Where are you seeing you have used only 106.5 MB? If on your phone, it may reset each month, giving you an inaccurate count.
Photo of BobTheElectrician
BobTheElectrician
  • 69,778 Points 50k badge 2x thumb
Phone re-set date is arbitrary, doesn't automatically match your baseplan, which is 30 calendar days, not one calendar month.
Photo of Peter Muir
Peter Muir
I did a restart didn't work the first time. Then I added another $50.00 to my booster. Acct is active and current. Still didn't work... Did a phone restart. Then it worked. Basically wasted another $50.00
Photo of David
The booster will still be there when you need it. Not exactly a waste of $50, just an earlier purchase than planned.
