Please help!
 I can't access my data, but I can call and text. What is happening? Thanks.
Photo of Grace Suva
Grace Suva
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Ivan
Ivan, Mobile Master
Make sure your data is turned on. If it is, you can perform a reset of your network settings under SETTINGS > GENERAL > RESET > RESET NETWORK SETTINGS. You'll lose your WiFi passwords, but the rest of your data will be fine.
Photo of Grace Suva
Grace Suva
It worked thank you!
