Plans with included minutes & unlimited evenings/weekends
  • Updated 2 years ago
Looking at plan /w 500 Canada-wide ANYTIME mins & Unlimited evenings/weekends. Does that mean if I use the 500 on evenings/weekends (free) that I start to get billed for daytime mins after that? Or are the 500 actually daytime mins?
Photo of RwB
RwB
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Shawn Chen
Shawn Chen
Should be daytime minutes.
Photo of Daniel
Daniel, Employee
  • 5,712 Points 5k badge 2x thumb
Hi Rod! I can confirm that the 500 Canada-wide minutes are for weekdays from 8am to 5pm. Hope that helps :)
Photo of Bill Flynn
Bill Flynn
hi rod, i have same plan, but im charged for everything over 500 minutes not getting nights and weekends free after 5 ? how do i get this corrected?
Photo of Bill Flynn
Bill Flynn
opps mean Daniel !!
Photo of BobTheElectrician
BobTheElectrician
  • 62,064 Points 50k badge 2x thumb
You may have to check with Koodo to verify what you actually have. Once discontinued, details about older plans are usually dropped from self-serve access.
If today's $40 a month plan is in your price range, then change your plan for the current  one.
https://www.koodomobile.com/rate-plans?INTCMP=KMNew_NavMenu_Shop_Plans
Photo of RwB
RwB
Thanks! Glad to have that clarified.
Photo of Jru Gordon
Jru Gordon
  • 9,038 Points 5k badge 2x thumb
there is also an LTO (Limited Time Only) plan offered where you can pay $35+Tab (anywhere from $5 for the Galaxy Prime to $15 for MOST other phones) and get Unlimited Canada Wide Calling and Unlimited Worldwide Texting, with Pay Per Use Data at $7.50 per MB
