Plan Switcher SVP
I would like to change my pre-paid plan to self-serve to take advantage of the roaming rates. What are the steps?
Photo of John Corcelli
John Corcelli
  • 346 Points 250 badge 2x thumb
Photo of Chris Petersens
Chris Petersens
Do you mean you want to switch to a monthly plan? Prepaid cannot be used for roaming outside of Canada. If you want to switch you will need a new SIM card and koodo will also run a credit check. Go to a koodo store they will sort everything out for you.
Photo of Dennis
Dennis, Mobile Master
  • 196,816 Points 100k badge 2x thumb
You will basically need to create a new account and sign up for monthly like a new customer and port your prepaid number over.
If you port your number over you will effectively be canceling your prepaid service and forfeit any boosters you have in your prepaid account
On the plus side you can use your current phone and get an additional 10% off your rate for doing so.
Photo of Dennis
  • 196,772 Points 100k badge 2x thumb
Visit a Kiosk. They can set you up with a new account.
Then they can port your number.
Now, are you really really sure you want to port your number to a monthly plan just for the privilege to roam? And lose all your boosters?
Are you looking to roam so you can use data or text or talk?
How long are you going to be roaming?
Where are you traveling too?
John Corcelli
Answer to first question is yes, simply because I'm not looking to throw good money after bad. In other words, if I unlock the phone it's $35 and I don't know the price of a new sim card on top of that. I'm looking to have a fully functioning iPhone south of the border.
Answer to second and third question: as a pre-paid customer my iphone won't work in the USA where I will be for about 10 days beginning July 29.
Photo of Dennis
Have you thought of unlocking your iphone and then using a USA prepaid sim like David said below
Here are some prepaid rates in the US
http://prepaidwithdata.wikia.com/wiki...
John Corcelli
Yes, thanks. What does Koodo charge for unlocking my iPhone?
Photo of Dennis
$35
John Corcelli
Thanks for the replies. I'm disappointed with Koodo and their strict policies and inflexible plans. I'm a prepaid, monthly subscriber committed to the Koodo and their services. I researched heavily before choosing a provider, and took some very good advice from friends and colleagues before taking my business specifically to Koodo.
Can you see the unfairness of losing my prepaid boosters?
Can Koodo understand how they will lose me as a customer altogether under these terms?
It won't be the same account. It's a totally different system. Prepaid and postpaid have their own unique advantages and disadvantages. Nothing in either system if transferable.
John Corcelli
Okay...fair enough. Thanks for the support!
John Corcelli
btw: here's the fine print regarding a 10% discount for monthly plans.
(1) Not available if you have negative Tab balance. No positive Tab balance will be earned. Discount does not apply to voice and data overages, taxes, credits and late payment charges. Excludes Koodo Prepaid.
You would start with 0 tab since you're bringing your own phone,
you won't earn a positive balance since you're getting the discount because that's kinda double dipping.
Discount applies to your plan, not your overages above your plan. And they certainly won't five you a discount for being late! :-)
John Corcelli
Understood. I'm guess I'm looking for a good rate and the least hassle regarding the whole process. Thanks for the straight-shootin' advice!
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
John, did you consider keeping your prepaid plan, unlocking your phone and simply using another prepaid provider while in the US? Many people go this route with VERY satisfactory results, money-wise. Yes, it involves swapping your SIM out with the US one, but it's not that big a deal.
When back in Canada, you re-swap your Koodo SIM back in and you resume where you left.
It's what many of us do!
Give it some thought before you do anything irrational like cancelling prepaid :oP
Photo of Jonathan I
Jonathan I, Mobile Master
Well you can always keep that Canadian phone # if you switch from Koodo prepaid to postpaid or even leave Koodo altogether. When you get the US prepaid phone #, your old one stays intact. Your phone #/account are tied to your SIM card, not the phone itself or where you're located.
Photo of Ray
Ray
  • 7,756 Points 5k badge 2x thumb
Last year when I went to the US for a week, I took my unlocked phone to an AT&T shop and signed up for a $2/day plan (unlimited US calls and SMS) plus $5 for 250 minutes of international calling. Since I had wifi in most places, I turned off data (they charge $0.01/5 kB). Total cost was $20. T-Mobile will probably be cheaper if you use data, but their coverage can be spotty outside big cities.
Photo of Ivan
Ivan, Mobile Master
You can buy Roam Mobility SIMs at Future Shop.
Photo of Ivan
Ivan, Mobile Master
To add to Chad's comment about Wind. Your iPhone may not be compatible with their network in Canada (and you may not get the best coverage while roaming in the US with them if their roaming partner in the area is T-Mobile for the same reason).
If you have an iPhone 5C/S, then you're fine. If you have a 5, check your serial number for compatibility. The list of compatible iPhone 5 models can be found here: http://support.apple.com/kb/ht5720
If you have an iPhone 4S or older, then it's not compatible.
John Corcelli
Thanks for all the suggestions. I've made a decision and changed plans. Better for me and my budget.
