plan help!
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
I have just changed my plan from a 20 dollar plan to the 30 dollar. I should be getting the option to now have voicemail and caller ID however I have not. Does the plan not kick in for 24 hours or something like that?
Photo of Naomi Rutledge
Naomi Rutledge
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
It should be in effect right away OR a couple of minutes, if anything.
Turn your phone off for a minute then back on.
Photo of Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Naomi, is it working now? Keep us updated! Thanks!
Photo of John Lee
John Lee
  • 36,704 Points 20k badge 2x thumb
It should work instantly. Try doing a battery reset, which is taking out your sim card and your battery for about one minute and then restart your device. Also, confirm on Self Serve that the plan has indeed changed. (There may have been an error). If all fails, you can contact Customer Care for free on your phone by dialling *611.
