Pixel XL having microphone issue
  • Updated 1 year ago
Hi,
Unfortunately, I found out my Pixel XL has the microphone issue mentioned here.
http://www.greenbot.com/article/31791...
It doesn't work but transiently, once in a while would work.
What's the warranty procedure? I'm also studying outside the country at the moment
Photo of ron
ron
  • 152 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 56,776 Points 50k badge 2x thumb
You will have to take it in to your closest Koodo store and/or request a returm mailer. If it is within 15 days you can return the phone (although you probably can't pick up a new one as they will most likely be sold out still unless they have one kicking around), or if it is within one year they will send it away for repair.
Photo of ron
ron
How long does the process take? I only have around two weeks before heading out
Photo of Ivan
Ivan, Mobile Master
Koodo only handles the shipping on your behalf to save you the charge. Warranty repair is done by Google. I'd recommend contacting Google about your warranty options while you are outside the country.
