pin reset
  • Updated 8 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
How do I reset my account pin?
I can't remember it and every number I call wants to know my pin number. ..... Any idea how frustrating this is! !!!?
Photo of Leon Dubitz
Leon Dubitz
Photo of Dennis
Dennis, Mobile Master
  • 195,900 Points 100k badge 2x thumb
You will have to call Koodo customer service and have then verify your identity via other means and then ask them to change or tell you your PIN
*611 on your Koodo cell. It's a free call
Photo of Diana Cross
Diana Cross
What do you do if you're out of the country and *611 doesn't work? Is there a number that is not a 1-800 number that I can dial from a land line?
Photo of Dinh
Dinh, Mobile Master
  • 41,300 Points 20k badge 2x thumb
Koodo number is: 1 (866) 995-6636
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,436 Points 100k badge 2x thumb
You can reach koodo from abroad at +1 647-788-4337. If you have internet access though, Facebook messenger may be the better option.
Diana Cross
Thanks! The number worked!!!
