Pin?
Don't know my "pin" to check my voicemail, how can I reset it?
Photo of Bobbi-Lynne R
Bobbi-Lynne R
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
I think you would need to call in to do that!
Photo of Sheila
Sheila
  • 1,780 Points 1k badge 2x thumb
Your PIN is used when you call into care and use their automated phone system. If you've forgotten password for voicemail, you can reset this on your own...here's the info on it
http://help.koodomobile.com/plans-add...
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
Log into self serve > Plans & Add-ons > Reset voicemail password
Photo of Sophia
Sophia, Mobile Master
And just in case you're on prepaid: self service -> Base Plan & Boosters -> Reset Voicemail Password :)
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi there, the default voicemail password is the 10 digits of your phone number :) You'll then have to choose a new one! Have a good day!
________________________
