picture texting, charged for data use?
I have an iphone 4. I have picture text for free with my plan, but am unable receive them. I believe that I have to have my data turned on to receive them, if I do that will I be charged for turning on my data?
Photo of Lynda Hollohan
Lynda Hollohan
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,038 Points 100k badge 2x thumb
You won't be charged for data used to send or receive picture messages (mms), however you will be charged for anything that syncs/updates/notifies in the background when you turn data on. To minimize this cost turn on data when you want to revive a picture message and then turn it immediately off after it downloads to your device. There is no way around being charged a little bit fir background data when turning on your data connection on a stock iPhone & can only be set up to only allow data for the transfer of pictures with nothing else accessing it is if you jailbreak your iPhone.
Also when you turn on data to accept a photo first close all apps to also help minimize background data transfer.
Photo of Dennis
Dennis, Mobile Master
  • 177,986 Points 100k badge 2x thumb
And also if the iphone is unlocked. This will grant you access to change the APN settings.
It is incredibly hard to stop data leakage as so many apps (stock and otherwise) will use data if available (notifications, email, icloud, etc).
An alternative is to do it when you are connected to wifi. However if you lose the wifi signal your are in the same situation.
Also when you phone goes to sleep, wifi turns off to conserve power and data is being used again.
  • 60 Points
I have the same problem, so I try to do picture texts only in wifi zone but if I have my data turned on and I am in a free wifi zone - will the phone use the wifi first or use the data first?
