picture not working
My picture are not working in my text
Photo of Jeremi St- Denis
Jeremi St- Denis
  • sad
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,476 Points 100k badge 2x thumb
Is your mobile data turned on?
Photo of Jonathan I
Jonathan I, Mobile Master
Make sure data is enabled in your settings. Picture messages require data access to work, but since your plan includes unlimited texting/MMS, you don't actually "use" data when you send a picture.
If you don't have a data plan, however, make sure that other apps aren't set to auto-update/sync when you turn on your data or else you'll be charged for it.
There's a thread around here that will detail how to enable MMS when you turn on data but disable data transmission outside of it. I'll dig it up for you.
