picture messaging problem
  • Doesn't Need an Answer
i have bb 9900, got it unlocked and now im using koodo sim. I have picture messaging in my plan but cannot send it. doesn't even get attach option in my text but when I try my sim in some other phone it atleast lets me attach picture but never delivers the text. it always shows error and doesn't send.
Photo of Ridze rishi
Ridze rishi
  • 90 Points 75 badge 2x thumb
Did you choose the BlackBerry specific version of your plan?
BlackBerry prior to BlackBerry 10 devices require special provisions so they can access the BlackBerry Internet Service (BIS). These provisions are only active of your plan allows it. Check selfserve for the name of your plan. I'd it doesn't say (BB) at the end of it, you won't be able to send or receive mms (picture messages) .
If not just change your plan to the BlackBerry version right there in self serve.
If you do have a BlackBerry version of your plan, you may just need to update your service books.
From your Blackberry, go to Options, select Advanced Options, select Host Routing Table, press the Menu button, select Register Now. You will shortly receive a confirmation message on your device.
Ridze rishi
how do u change it to bb version? and when should i receive a confirmation message?
Log into self serve, choose the "plan" tab. Click change plan. There's a list of devices, click it until you see the older style BlackBerry plans.
Ridze rishi
i dont see the plan i have in the list
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Another possible need after you do what Chad suggested if things still don't work make sure you put in the Koodo APN settings.
http://koodomobile.com/en/ab/non-kood...
Photo of Myke
Myke
I don't believe Blackberries have the ability to customize the APN. On older Blackberries, registering the Host Routing Table programs the APN into the phone.
Photo of Jorden
Perfect! Always good to learn something new :). Thanks Myke!
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hi Ridze, Are you still having the same issues? Please keep us posted.
________________________
