Picture text messaging not working on BlackBerry Z30 (Prepaid plan)
  • Updated 2 years ago
  • (Edited)
Every time I send one, it shows the little clock icon in the upper left corner and a eventually a error message appears "Send interrupted by restart ". How do I get my pic messaging to work? The phone was bought unlocked at staples 4 months ago. It runs on the newer BlackBerry 10 network. Thanks.
Photo of shelley
shelley
  • 2,884 Points 2k badge 2x thumb
Posted 2 years ago
Photo of shelley
shelley
I should add I tried sending picture text messages with WiFi at home. I have a date booster but haven't tried sending using data instead it WiFi.
Photo of Andrew
Andrew
  • 1,392 Points 1k badge 2x thumb
In order to send a picture message it requires data to be enabled, it won't actually use data or charge you for it though.
Photo of shelley
shelley
Thanks Andrew. I assumed I could use WiFi to send pic messages. I will try my data. I assume it's the same when someone sends you a pic message? My data would need to be in on in order to view it?
Photo of Jonathan I
Jonathan I, Mobile Master
Yes. This is a requirement of 3G+ networks.
Photo of Sam Dmitruk
Sam Dmitruk
  • 384 Points 250 badge 2x thumb
I would be wary of relying on WiFi to send MMS.  From my understanding of MMS Messaging it relies on cellular data to send them and cannot be accomplished via WiFi.
