Phones Data period vs Actual Data Period.
  • Updated 1 year ago
So I've updated my old Nexus 5 to a Moto Z Play and the only problem I have is the dates. My bill is actually today to the end of the month but my phone has it set from Dec 19th to January 18th. I was hoping there is a way to change it on my phone. I would prefer the phones built-in usage information as opposed to downloading an app that helps tell me how much data I have used. I am hoping someone called help me. I tried clicking on it to change the date but it didn't work.
Photo of Nathan Downey
Nathan Downey
  • 274 Points 250 badge 2x thumb
  • annoyed, bothered, confused, perplexed
Posted 1 year ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,560 Points 100k badge 2x thumb
I believe you have to enable data and then click on the date and I adjusting the date should show up
That said it is best for you to use Koodo's data counter as the built in phone one won't be as accurate.
Nathan Downey
I ended up getting it after I had to turn off automatic date and time then I set the date for January 18th which would have been when the cycle changes and it then asked me if I wanted to change the date of the cycle and I set it for the first of each month. But it's set up now so I'm happy. I appreciate the help though.
Photo of Dennis
Dennis, Mobile Master
  • 187,596 Points 100k badge 2x thumb
Settings>Data usage.  You should be able to change your data usage period here
Yeah but she's saying the option doesn't show up, she knows where it is
Photo of Dennis
Click the drop down that has the incorrect billing cycle and you have a menu option called "Change Cycle"
Nathan Downey
