Do you carry any phones that are not smartphones?
Photo of Tessah MacDowall
Tessah MacDowall
  • 250 Points 250 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Yes, they do, Tessah, not many pickings I'm afraid, only one currently. Check out this link:
Photo of Daniel Kim
Daniel Kim, Mobile Master
Are you sure you don't want a smartphone?There are lots of great affordable options! They're also fairly easy to use if that's why you want a non-smartphone. :)
Photo of John Burke
John Burke, Mobile Master
  • 71,336 Points 50k badge 2x thumb
Is there a particular reason you don't want a Smartphone?
Photo of John Lee
John Lee
  • 36,704 Points 20k badge 2x thumb
What? Why don't you want a smartphone? All phones nowadays are smartphones, even if they are low tier.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,756 Points 100k badge 2x thumb
Im guessing you possibly dont want to have the data costs that can occur with a smartphone maybe? Well you can always get a smartphone and have data (internet) disconnected from koodo basically turning it into a non smartphone. Then you have the option if turning it into a smartphone when you want. Then you can use the internet over wifi if you want.
If its being worried about not understanding how to use a smartphone you can turn some smartphones (samsung Galaxy's) on "Easy Mode" in the settings and it will give you a very simple user experience thats very easy to learn and use for smartphone beginners. I think the Galaxy Ace 2x has this option in the settings menu, just ask the sakes person.
You can also download a few applications called launchers that will make a very simple user experience. One great ones "Big Launcher" and its available in the Google PlayStore.
Photo of rikkster
rikkster, Mobile Master
  • 66,312 Points 50k badge 2x thumb
Could serve as an inexpensive emergency/spare phone.
