Phone wont turn on
  • Updated 2 years ago
Samsung galaxy ace 5830 is not switching on its showin mdl factory download mode bootmode = [fcde8462] , [f1e2d3c] hw rev : 5
Photo of Kyle-Robyn Matthews
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
is there A scrollable list of options showing that when you hit the volume button it scrolls up or down the list?
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
Couple of things to try first.
Remove and re-install battery, but don't power on the Ace.
Press the centre Home button then press the Power button and hold for approximately 15 to 20 seconds. This should get you into the Android Recovery Utility. To scroll up or down, use your Volume up/down rocker button. Use the Power button, (like an enter key) to select the desired option.
In this case, you will want to scroll down to the "wipe data/factory reset" option. The Ace should reboot back to factory default.
If you can't get to this stage, you will need the following tools:
Ace tethered via USB to a laptop or desktop Mac or PC.
Odin 4.38 - this allows you to flash the Koodo stock ROM onto your Ace
http://www.filecrop.com/odin-v4.38.html - look for a multi-loader version.
Download the stock Koodo ROM below.
http://www.hotfile.com/dl/191393235/b...
Password for the .rar file: sampro.pl
Once you have Odin installed and open, you'll want to place the Ace in "download mode". With Ace off, press and hold the Volume down key and Home button together, then press and hold the Power button - keep all three buttons pressed until you see a pink screen that says Warning!! Use your Volume up key to enter download mode - "Downloading.." should be shown in yellow text.
To verify that Odin has found your Ace, the first box labelled ID:COM should turn yellow and the word PASS should appear. This means a com port has been opened and that your Ace can communicate with Odin.
The only box you should check off is PDA. Click on the PDA button to locate the stock Koodo ROM zip file you downloaded earlier and select it. Click the Start button in Odin and within about ten minutes (give or take) your Ace will reboot itself and should be up and running.
That's star worthy for sure
Photo of Shyam Ambilentavida
Shyam Ambilentavida
Remove battery, switch on phone by pressing home buttom, this will take u to recovery. Select 'reboot phone now' option.
This sequence worked for me!!!
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Welcome to the community, but please keep an eye on post dates. This topic has been marked as answered, and no one has posted in it for 7 months. Likely the original poster does not need help anymore.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
This was answered 7 months ago...
Thank you so much for your information it worked for me!!!
