Phone Won't Connect to 4G LTE Network
After updating the software on my z10 it won't connect to the 4G network, only one called "h voice only" so nothing that uses data works when I leave my wifi area. How do I reconnect to the Koodo network?
Photo of Steve Gignac
Steve Gignac
Does your screen look like mine? (minus Tmobile)
Photo of Jonathan
Jonathan
  • 816 Points 500 badge 2x thumb
Make sure DATA is on, if i understood you are able to make calls right?
Steve Gignac
Data is on. Instead of T-Mobile it says Koodo h - Voice only
Shut it down
Remove battery and sim
Wait 1 full minute
Replace all.
Photo of Rocky Balboa
Rocky Balboa
If the data is on try unplugging the battery and sim while the phone is on. Plug back in after 15 seconds power back up the phone and try again. It it still doesn't work you may want to contact tech support for further assistance.
Photo of Jonathan
Jonathan
Try removing Batt and SIM and if it doesn't work something might have gone bad during the update, so try to reload the software this link might help ► http://crackberry.com/how-reload-os-b...
Steve Gignac
Neither worked.
Photo of Jonathan
Jonathan
give me a few secs,
Waiting....
Photo of Jonathan
Jonathan
Try performing a master reset
Before you do that use the link software to backup your apps only using the selective backup settings. That way you don't have to re-download all that stuff. You can back up the settings too but don't restore them unless Jonathan's suggestion doesn't work.
Steve Gignac
I backed up and then did a factory reset. The APN is now sp.koodo.com and i'm on the 4G network. So something went wrong during the update and the APN settings get messed up.
Toggle your wifi
