Phone vibrates randomly
i°m having a sumsung galaxy s2..suddenly it switched off and started vibrating. I tried switching on but it loads and turns off again and also the only possible way to stop the vibration is by taking the battery off.. Could someone please help me fix it ?
Photo of oshini wijesinghe
oshini wijesinghe
Is it a random vibration or is it like every two seconds?
You're probably going to need to boot into recovery and do a factory reset.
Something is wrong. Here's is a video showing how to get the device into recovery mode and do a reset.
http://youtu.be/q23KvYy-CzA
oshini wijesinghe
it is switched off now. it doesn't switch on when i insert the battery the only thing what happens is that it vibrates every second
Okay you may have a stuck power button. Try fiddling with the power button next time you insert the battery. Move it all around.
oshini wijesinghe
Thnkyou soo much! itès working now :D
Fantastic, glad I could help!
oshini wijesinghe
thank you. I tried doing that,but unfortunately the phone keeps vibrating as soon as i put the battery on.I doesn't take me to the recovery mode.
How long have you had this phone?
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
Is your case holding down the power button? I own the Ace 2x and when the power button is being held down for a long period of time it shuts off then continues to vibrate until the power button is let go or un jammed.
