Phone turns off randomly, doesent turn on unless plugged in.
I have a Galaxy ace x2, i cannot turn on my phone without it being plugged in, and if it isnt plugged in it will turn off within 3-10 minutes. Is this a bad battery or just an easy fix?
Photo of Jesse MacDonnell
Jesse MacDonnell
Photo of John Lee
John Lee
It could be that the battery is not working anymore so you can try putting a new one but if the phone is old, it could also be that the phone is breaking down. Going to need more information.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
What's battery indicator say when you turn on your phone? Low battery or 100% charged...?
It could be the battery as John said, or it could be the charging port.
You can bring your phone to the nearest Koodo shop to send it for repair if it's still under warranty.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
Generally, if more than a year old, batteries tend to lose their ability to hold a charge, or can only power the device for more than a few minutes. The symptom you describe points to a failing battery and a new battery should fix the problem.
Photo of Daniel Kim
Daniel Kim, Mobile Master
http://www.amazon.ca/Battpit-trade-Ba... or your warranty may still apply as long as there is no signs of physical damage or water damage on the phone and it's been under a year.
