phone too hot
w;hy does my phone heat up ... sometimes it's very hot
Photo of Shirley Brown
Shirley Brown
Photo of Dennis
Dennis, Mobile Master
  • 178,294 Points 100k badge 2x thumb
Sounds like a defective battery or a battery past its prime?
Is this a new phone?
Photo of Chris Petersens
Chris Petersens
  • 47,246 Points 20k badge 2x thumb
The battery. Most laptops, cellphone will do that to a point. It's normal use. If yours is so hot that you cant hold it in your hand I would have it chekcked out. It maybe faulty.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,200 Points 100k badge 2x thumb
Is it when your using it, say playing a game? If so it's normal it's the processors in the phone working. If it while it's just sitting there doing nothing that isn't normal.
Try installing this app & when it gets hot check the temp it shows. It should also alarm if it get dangerously hot
Photo of Chris
  • 2,056 Points 2k badge 2x thumb
^ Paul - how do you know the OP has an Android handset when nothing was said? ;-) Android may have the highest market share now, but don't assume everyone uses it! :-D
  • 193,128 Points 100k badge 2x thumb
Your right, my bad I should have specified if they have an Android.
