Phone says will not update firmware? Galaxy S2 X
  • 2
When Jelly Bean Rolls out will I have an issue?
Photo of David Coxe
David Coxe
  • 160 Points 100 badge 2x thumb
  • 2
Photo of justin
justin
  • 1,488 Points 1k badge 2x thumb
I think that message you received from "Kies" just means that there isn't an OTA update available for your device from your provider or carrier yet. Once it is made available, then I would check "Kies" again to have the firmware updated.
Hope that helps...
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
It's a "tethered" upgrade for the S2x, not an OTA upgrade. The S2x doesn't have the ability to update/upgrade over-the-air. Everything else you've mentioned is correct.
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
Don't think so any issue
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,538 Points 100k badge 2x thumb
What version of Android are you running on your Galaxy S2x right now?
Photo of David Coxe
David Coxe
Kid Android I am running 4.0.4 on my S2X
so have you not updated the phone once already using KIES?
Photo of Jonathan I
Jonathan I, Mobile Master
After the 4.0 update was pushed out to Telus versions of the S II X, the phone was rolled out on Koodo. All S II Xs ordered/bought on Koodo come with ICS out of the box so he most likely never updated through Kies before.
Oh I thought Koodo just got Telus overstock of the Galaxy S2x, I guess it's been so popular that even if they did those would have been gone ages ago. Your right.
Photo of Jonathan I
I guess they might have, but the rom was modified to run ICS by default and Koodo pops up on the start up screen.
Photo of johnwmartins1996
johnwmartins1996
  • 214 Points 100 badge 2x thumb
Tmobile has jellybean should be us soon!!!!!!
