Phone plan for kids
What plans are available to get a phone for my son that only can call like 4 numbers? We don't have a home phone and he calls me at work when he gets home from school.
Photo of Lynn Wareing
Lynn Wareing
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
How old is your son?
If you need basic plan for him, the Prepaid plan plus Talk Booster would be ideal :)
http://koodomobile.com/en/on/plansand...
You can get a Certified Pre-Owned phone to start.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
You can get any postpaid plan or even better get a prepaid account and then you'd actually set up the phone to only allow specific #’s to be called or text. Make sure if you do get a postpaid plan that you have them disable data on koodos end so that data can not be turned on or used as data could run up your bill very very quickly.
I believe the Moto G has fixed # dialing to allow only certain #’s to be called and its an awesome phone that is even water resistant so if they happen to drop it into the water it won't get damaged and a battery that last longer than any phone on the market pretty much all for only $150 or $0 on a small tab.
