Phone locked with too many pattern attempts
  • 2
Phone locked with too many pattern attempts. Can Koodo supply a username and password? i don't remember setting this up originally. It's not the same info I use to access the web account.
Photo of Stephen MacLeod
Stephen MacLeod
  • 2
Photo of Ahmad
Ahmad
Koodo can't help you. I see you have an android phone and it's your Google Play store log-in information you need to put it. So the gmail email you used to sign up and password. If you can't remember, unfortunately you'll have to factory reset the phone.
Photo of Admir Velagic
Admir Velagic
Which phone do you have ? You will have to do a hard factory reset if you do not remember your gmail password as stated by Ahmad. Google your phone model and " hard factory reset " .
Photo of Dennis
Dennis, Mobile Master
  • 196,080 Points 100k badge 2x thumb
Is that IMEI correct? It says invalid when I tried to look it up
http://www.imei.info/
Dial *#06# to see your device IMEI
Photo of Dennis
Or in Settings try to find About Phone/Device to find the model number
Photo of Loretta Humber
Loretta Humber
  • 90 Points 75 badge 2x thumb
it's a E400 Optimus L3.
Photo of Mark Manson
Mark Manson
  • 80 Points 75 badge 2x thumb
you can reset the pattern lock by using the steps mentioned in this article: http://www.what-is.in/howto/reset-android-pattern-after-too-many-wrong-attempts.html
Stephen MacLeod
Thanks for the responses. I had to do a factory reset. Luckily, everything (except the apps) were backed up with the Samsung Kies software, so all was restored.
Cheers!
