Phone does nothing even if plugged into a charger.
My i-phone 4 is dead and won't take a charge. I plugged it into a wall charger, if it wont turn on, is it the dead battery or something else. Can you make a call with the charger if the battery is dead. I want to know before I spend money on a new battery.
Photo of brian pfeiffer
brian pfeiffer
  • 160 Points 100 badge 2x thumb
Photo of Ahmad
Ahmad
If you're still within warranty (within one year of purchase), you can go to any apple store and they'll most likely replace it for you, free of charge. If you're outside your warranty, I still recommend you go to the apple store as they can try to asses what's wrong with it and let you know whether or not you need a new battery or a new phone altogether.
No you can't make a call with the charger
Photo of KaneSlavik
KaneSlavik
  • 6,464 Points 5k badge 2x thumb
Your last sentence made me chuckle. Just picturing someone making a call with just the charger next to their ear :P.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
That was a serious question? :/
Photo of Rocky Balboa
Rocky Balboa
You'd have to take your phone into an apple store. Iphones have the battery built in so there's no way to remove it.
Photo of quasarito
quasarito
I think OP meant "can you make a call with a phone that is plugged in to a charger"...
In general, you can. But in OP's case, it looks like the phone won't even power on with the charger plugged in.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Sometimes this happens and you can fix it by just holding both buttons for about 30 seconds or so until an Apple logo appears on the screen.  If that doesn't happen then follow Ahmad's suggestion above.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
Although rare, it could be a faulty charger or the usb data/power cable could be defective. You could try charging the iPhone from your computer via usb port to determine if the wall charger is at fault. If that fails, follow the above suggestions for returning the device to the Apple store. Bring the usb cable and wall charger so they can inspect these items as well.
