Phone displays 4G not LTE
Hi I have Note 3 Samsung and I was using data a few hours ago at my local gym and it showed a LTE logo on my status bar When I was connected but now when I reconnected a few hours later it now shows the 4G logo on my status bar? How can I revert to the LTE logo showing is it because I'm not in a LTE zone? Thanks
Photo of Gurj Bajwa
Gurj Bajwa
  • 340 Points 250 badge 2x thumb
Photo of Myke
Myke
Yes. You need to be in a LTE zone to be able to connect to LTE.
Photo of Gurj Bajwa
Gurj Bajwa
So if I'm not it will show up as 4G?
Photo of Jonathan I
Jonathan I, Mobile Master
Yes.
Photo of Gurj Bajwa
Gurj Bajwa
Okay thank you! I was getting paranoid because it showed LTE earlier my connection says LTE/WCDMA/GSM (auto connect)
Photo of John Lee
John Lee
Yeah, when you're in an LTE zone, you'll automatically get LTE if it's enabled. If not, you'll get normal data speeds.
