Phone wont turn on due to water damage, can I get it replaced?
  • Updated 2 months ago
So I had to quickly save a family member who was about to drown in a pool, but I forgot to get my phone out of my pocket before making the save. I dried it and put it in rice but after a few days in there it won't turn on or even charge so I think it's officially dead. Is it possible that koodo will replace my phone?
The phone is a Samsung Galaxy Grand Prime.
Photo of Noel Kisanga
Noel Kisanga
Posted 2 months ago
Photo of Mats
Mats
  • 22,156 Points 20k badge 2x thumb
Yes you can get your phone replaced but probably not for free. Usually water damage will void any warranty.
Photo of Dinh
Dinh, Mobile Master
  • 42,056 Points 20k badge 2x thumb
@Noel: When did you buy the phone? and do you have Koodo extended warranty on it?
As Mats suggested, manufacturer doesn't cover water damage.
Noel Kisanga
@Dinh: It was given to me as a gift about 2 years ago, and I don't remember if I have extended warranty on it. Alright, so I won't have to buy a brand new phone?
Photo of Dinh
Dinh, Mobile Master
eh, if someone bought it for you, then you properly didn't have the extended warranty on it.
Your phone was out of warranty with water damage, I don't think Koodo/Samsung will do anything for you. A new phone is likely the choice.
Photo of Allan
Allan, Mobile Master
  • 62,694 Points 50k badge 2x thumb
If you had the extended warranty then you may be able to make a claim if the warranty period hasn't expired. All of which you should have documentation for.
Otherwise, you'll have to get a new phone or get the current one fixed.
Noel Kisanga
Well shit.
Photo of Mats
Mats
Yes you will have to buy a new phone. The phone was given to you so any warranty(if any) wouldnt apply to you. Plus the phone was put in water so...........
