Phone won't connect.
  • 2
  • Updated 1 year ago
My phone has been «searching...» since  yesterday. It won't work unless I'm using Wifi?
Photo of Renaude Adéline Lagace
Posted 1 year ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
Restart your phone. If that doesnt work, take out the Sim card and wait a few seconds and put it back in. Does this happen anywhere you go regardless of location? Which phone do you have?
It's been doing it non-stop since yesterday morning no matter where I go.
I have an iPhone 5c.
Thanks !
Photo of Goran
Reset network settings if what I said above doesn't work: "Go to Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before."
https://support.apple.com/en-ca/HT201415
If that doesn't work, see if you can put your Sim card in another phone and ideally someone else's in yours if the problem follows or remains. If you cannot do this, then going to a Koodo shop you can have it done with a demo Sim and phone. If it's the Sim, it will need to be replaced.
Thank you !
