Phone Upgrade Will Change Base Plan?
  • Updated 3 months ago
I have no tab balance right now. If I were to get the Iphone 8, would the tab be added to my current plan of $45/month, or would my entire plan change? I don't want to lose my great rate.
Photo of Sara Kloot
Sara Kloot
Posted 3 months ago
Photo of Allan
Allan, Mobile Master
  • 59,830 Points 50k badge 2x thumb
If your current plan is $45/month you can get a phone on tab small or medium without having to change your plan.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 200,876 Points 100k badge 2x thumb
If you choose a tab small or medium you won't need to change your plan. You'll have the option when you select plans right at the top of the page that will allow you to keep your plan.
