Phone/Simcard problems
  • 2
  • Updated 2 years ago
I have a nexus 5 phone inside also has a sim and bought a new s6 edge but the sim doesn't fit. Can i get a new sim card and keep the same plan and number? Will i get the sim card the same day i go to the store and how much is it ?
Photo of Joelle Guevarra
Joelle Guevarra
Posted 2 years ago
  • 2
Photo of rikkster
rikkster, Mobile Master
  • 68,252 Points 50k badge 2x thumb
$10 for a new SIM card and you'll get the new SIM card the same day if you visit a Koodo shop. The S6 Edge takes a nano-SIM card. You can keep the old number by going into your self serve account and selecting Change SIM Card. You'll be entering the serial number of your new SIM card. The SIM card in your Nexus 5 can no longer be used from that point on.
Joelle Guevarra
Does it have to be a koodo shop? How bout like Ralcomm? a partnered retailer i think...
Photo of BobTheElectrician
BobTheElectrician
  • 66,674 Points 50k badge 2x thumb
You had better call ahead. My experience with retail partners is that they have little interest in answering the phone, let alone in selling a SIM only since there's no substantial commission attached.
Photo of rikkster
  • 68,186 Points 50k badge 2x thumb
They might, best to call ahead to see if they carry them. I noticed The Ralcomm Group is a licensed dealer of Telus Mobility. If not, a Koodo shop will have them.
Joelle Guevarra
ok thanks for the answer cheers
