Phone settings while travelling in Europe
  • Updated 3 months ago
While travelling in Europe, I will not use my iPhone 6s unless connected to Wifi. Do I simply set Data and Roaming to "off"?  Any other settings to deal with?
Photo of Dino
Dino
  • 102 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Yepp, and don't answer or make any calls or send any texts.
If you don't care about receiving texts you can turn your phone on airplane mode or remove your SIM as well.
Photo of Dino
Dino
With data and roaming both off, I could still receive phone calls?
Photo of Mats
Mats
  • 8,926 Points 5k badge 2x thumb
Ok sorry Dinh I didnt realize you were talking about add ons to your Koodo plan. I thought it was just phone setting that was being talked about.
Photo of Dinh
Dinh, Mobile Master
  • 30,110 Points 20k badge 2x thumb
@Mats: he was asking about a phone setting for data but then he asked the question of receiving "phone calls" while he is in EU. I was trying to align his need of roaming with Koodo roaming options.
Photo of Dino
Dino
To clarify..... I do not wish to receive or make calls while travelling.  I do not wish to receive texts or send texts.  I will just be using Wifi where available.  I just need to know how to set my phone to make sure I do not incur charges for data use.
Photo of Mats
Mats
airplane mode then turn on wifi
Photo of Dino
Dino
Thanks Mats!
Photo of Mats
Mats
  • 11,724 Points 10k badge 2x thumb
If you only want wifi put your phone in airplane mode then turn on wifi. Dont do it the other way around because if you do airplane mode will turn wifi off.
